Solid State Switching
Discussion in 'General Electronics Chat' started by Jsw123, Aug 5, 2009.
  1. Jsw123
    Thread Starter Active Member
    Jun 20, 2009
    43
    What is the difference between a solid state relay and a semiconductor contactor?
    Can both switch ac loads? This a link to a company that distinguishes between the two.
    http://library.abb.com/global/scot/scot209.nsf/veritydisplay/da7ec357f6a7461cc12573ad004e1e83/$File/2CDC110004C0205_07.pdf
  2. mik3
    Feb 4, 2008
    4,846
    63
    If they are designed to switch AC loads then they can do it. Solid state relays use transistors and thyristors (TRIACs) to make the switching whereas contact relays use moving contacts.
  3. Ron H
    Apr 14, 2005
    7,050
    657
