Is there such a thing? I would like to use an optical switch to turn LED's on and off. My circuit should run between 3-6 VDC and a little over 1 amp. Problem is that this is solar powered and I can't afford a power robbing relay.
I'm a novice at both electronics and forums. thanks a bunch.
