I am confused when to use a SSR like "S202SE2" and when to use a TRIAC like BT137. I am also more concerned with safety designs. For example, the lack of knowledge regarding adding a snubber circuit or not, adding a capacitor in a specific point in the circuit...etc.
In brief I need to design a "safe" circuit to control AC Lamp up to 200W, and also control heavy load devices up to 10A.
First design.
I searched a lot for a well designed TRIAC circuit but couldn't understand HOW the components values were chosen. In this link, the writer designed the cricuit using BT137.
My question: What values do I need to get from the datasheet which I can use to select R2, R3, R5, C1 and C2 ?
Second design:
Where I live, the S202SE2 is available ( datasheet ) Why and "how" would I use this and not the above TRIAC ? Do I need any external componets rather than the snubber circuit which is mentioned in the datasheet guide ?
Thanks.
First design.
Second design:
Thanks.
