Solid State Relay Connection
Discussion in 'General Electronics Chat' started by senghow1202, Mar 25, 2013.
  1. senghow1202
    Mar 22, 2013
  2. senghow1202
    Mar 22, 2013
    Any problem with the connection as circuit attached? I found that LED light always 'ON' no matter 5VDC is activated or not. Pls advise...
  3. crutschow
    Mar 14, 2008
    13,481
    3,368
    It may be the leakage current of the switch or the switch is shorted. Use an incandescent light bulb instead of the LED for a load and see if that works.
