solid aluminum caps
Discussion in 'General Electronics Chat' started by Gibson486, Apr 30, 2015.
  1. Gibson486
    Jul 20, 2012
    199
    12
    I am looking at Solid aluminum caps. How does solid tantalum caps differ from solid electrolytic/aluminum caps? From what I see, both are comprised as polymer. Looking on line, they both seem to have the same pros. Since most articles online are from the vendors themselves, they do not really say what the cons of each are. Any comments on this?
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    Looks the same to me.
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Where are you looking at solid aluminum capacitors?
  4. Gibson486
    Jul 20, 2012
    199
    12
    Digikey
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    I was wondering how anybody would make a solid aluminum capacitor.
    It turns out the electrolyte is solid.
  6. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Tantalum caps are far more stable over temperature fluctuations than aluminum caps, they also have a much longer lifetime.... and of course, are more expensive, especially at at higher capacitance. Also, commercially available tantalum caps seldom reach values of more than 100µF ... although values of up to 10,000µF can be found ... for a pri¢e ...
  7. cmartinez
    Jan 17, 2007
    3,700
    2,802
  8. #12
    Nov 30, 2010
    16,705
    7,358
    I'm not quite sure of this, but...a solid electrolyte could resolve several weaknesses in aluminum capacitors just by eliminating the liquid. Color me hopeful.
  9. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Your knowledge almost certainly surpasses mine... is your question regarding my assertion of temperature stability, or of its lifetime?
    Also, I'm under the impression that tantalum caps react faster than aluminum for ripple suppression... would that mean that they have a lower equivalent resistance?
    Again, of course I could be mistaken.
    EDIT: silly me, the table I just posted says that tantalum's ESR is higher than aluminum. Still, why is there less ripple in some sims when I change aluminum to tantalum?
  10. GopherT
    Nov 23, 2012
    6,330
    4,081
    Solid polymers and ionic polymer liquid electrolytes help that. Some newer technology aluminum electrolytics will last 'forever'. The manufacturers are not as optimistic as some of the materials suppliers so no clear identification on the packages yet - but, I am sure the facts and figures collected from the field tests will start to build confidence in the next few years.
    cmartinez and #12 like this.
  11. #12
    Nov 30, 2010
    16,705
    7,358
    It wasn't a question. I was just saying I am optimistic about eliminating liquids in aluminum capacitors. I think any metal in contact with a caustic electrolyte will eventually leak, and aluminum is notoriously active (chemically). And...this being new technology, I do not have an advantage over you. (I think) Both of us learned about this today.
    cmartinez likes this.
  12. cmartinez
    Jan 17, 2007
    3,700
    2,802
    So I guess we'll all have to wait and see... I'm working on an application in which the lifetime of a 400µF cap working at 12V will be crucial.
  13. #12
    Nov 30, 2010
    16,705
    7,358
    The latest information I have on that is: Using a capacitor rated for UP TO twice the actual voltage will maximize its lifetime".
    Personally, I have a 1978 thermostat still running with a 50 volt capacitor on a 12 volt supply (because that's what I had in the junk box). This makes me suspect the manufacturers note that I just quoted might be true.
  14. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Wouldn't the fluctuations in the cap (charge/discharge) affect its lifetime too? Say, if a cap is only being use to minimize ripple (as in decoupling a digital chip) in the long run affect it differently than when it's being used to stabilize output voltage, as in an AC to DC power supply?
  15. alfacliff
    Dec 13, 2013
    2,449
    428
    life time depends on heat, heat dries out electrolytics, esr increases, more heat, more esr, pops the top off or bulges it and no more cap. thats why dry types last longer. older caps used to last a long time, 30 years or so, newer ones sometimes less than 5 years before failure. the mfgrs dont want to admit that, but electrolytics are the most failed part that goes through my shop.
  16. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Thanks for the tip... so say, for higher temperatures, using ceramics would be the best (though probably also the most expensive) option?
  17. alfacliff
    Dec 13, 2013
    2,449
    428
    ceramics usually dont have the big mfd ratings. but they do last quite a long time.
  18. #12
    Nov 30, 2010
    16,705
    7,358
    I have never seen a defective ceramic capacitor.
  19. #12
    Nov 30, 2010
    16,705
    7,358
    What if they do? The only way you can protect your capacitor from the needs of the circuit is, "Don't install it". :confused:
  20. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Ok... let me clarify...
    Normally, if you install a cap at the output of a rectified AC source, under a light load the (unregulated) waveform looks like this:
    And under a heavier load, it would look like this:
    Wouldn't that affect the capacitor's lifetime?
