Correct me if i am wrong. I cant see how a megger test on a solenoid coil can be doneWho says you can't megger a solenoid?
I fully agree with you, that is the method i use and have always used, but i was thinking that there has to be some other way to do this with all these test equipment we got todayPlaying interrogator; By shorted coil, I'm guessing you mean turns of the coil shorted to themselves, not to ground?
Say you connect your coil to an LCR meter, it spits out a number. Does this number mean anything to you? Do you have manufacturer specs for inductance, capacitance, resistance? I'm guessing not. So what do you do? You probably at least have manufacturer's spec for amps. So if it were me, I would energize it, and if it doesn't actuate, or if it actuates weakly despite being mechanically easy to operate, or if it draws other-than-nameplate amps despite being fully actuated, then I call it garbage.
Im assuming you're coming from the stand point of meggering motors, where you check for leakage between phases. That still doesnt check for shorted turns within the motor windings. The other part of meggering a motor is checking for leakage to ground, which can still be done on a solenoid. Just attach your probe to the armature and other probe to the coil leads.Correct me if i am wrong. I cant see how a megger test on a solenoid coil can be done
I can tell you a few things that do not seem to work.
Expected a jump in current from an ac solenoid with a shorted turn.
It takes a large number of shorted turns in relation to the total turns to see a meaningful difference.
LCR meter changed only from 182mH to 180mH on a 120vac solenoid when shorting 5 turns.
Not very helpful.
Was not successful building a growler with the junk on my bench.
It may merit looking into. Not sure how a solenoid could be coupled for testing.
You mean they apply a voltage and see if they get the current that its rated for ?AC motors, transformers, usually with a current test, both in an off load or open condition.
Max.
This is about the most practical for AC devices, also if a frequency is applied to a DC device and the inductance is known.You mean they apply a voltage and see if they get the current that its rated for ?
I believe it would be the same.How about DC coils with LCR meters
