Hi folks
how is a solenoid tested, is it possible to megger it ?
Got a bad 110Vdc solenoid that I want to test, but using a multimeter I don't see any change in the ohm reading, I think this is due to the multimeter not supplying enough voltage to the solenoid to detect the fault, so is there another way to test it ?
The solenoid is bad because when energized it draws to much current and causes indication lamps that is supplied from the same power source to dim.
