Solenoid to Arduino (12v-5V)
Discussion in 'Embedded Systems and Microcontrollers' started by Mizs Faa, Nov 25, 2015.
  1. Mizs Faa
    Nov 25, 2015
    11
    Im looking for specific Mosfet to allow connection between 12v of Solenoid to 5v arduino. Is Mosfet IRF640 type suitable for this connection?
    Im gonna use 8 of solenoid valve that each of them using 0.2A therefore i might require mosfet with 4A current. Please guide me or give an ideas for this?
    Mods edit:
    Refer to another thread has been locked -- Urgent Help -Solenoid and arduino.
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Logic gate Mosfet IRL630.
    Max.
    Mizs Faa likes this.
  3. Mizs Faa
    Nov 25, 2015
    11
    So this kind of Mosfet suitable for my connection circuit? BTW thanks for the idea. I am really appreciate it :)
  4. Mizs Faa
    Nov 25, 2015
    11
    Sorry for interrupt, im having some inquiries. Using solenoid valve Normally Open 12V/02.A which is controlled by Arduino Mega because im gonna use 8 input of solenoid (8channel). Therefore im looking for mosfet that can carter for 4A of current. When im go through some datasheet im getting confius since a lot of ideas give variety type of Mosfet that i should use.
    This is few Mosfet that i found :
    -IR640
    -IRL630
    -IRF530
    Which one should i refer? Or is there any info should im look in datasheet as my reference? Im sorry because im out of ideas how to refer through datasheet. Its thankful if someone share their knowledge to me about this. Im glad to hear from you all.
    Best regards,
    Faa
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    If all the solenoids are to be activated at the same time then won't only one control channel (input) be needed? For individual control of the solenoids you will need 8 MOSFETs.
  6. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    The L signifies a logic level device which you need if driving it from an Arduino.
    Max.
    djsfantasi likes this.
  7. mcgyvr
    Oct 15, 2009
    4,787
    973
    If you want to control each independently (8 channel) then you need a mosfet for EACH solenoid.
    And you want a logic level mosfet so it will be fully on with only 5V
    in one spot you said .2A in another you have 2A so...
    With the IRL630 if your solenoid is .2A then you won't require a heatsink on the mosfet..
    If the solenoid draws 2A then you will
  8. Mizs Faa
    Nov 25, 2015
    11
    According to my plan, I gonna connect one solenoid with one mosfet.. Is there any other solution to connect in one set or there is only option for me?
  9. shteii01
    Feb 19, 2010
    3,500
    511
    While that solution uses more parts and perhaps takes more space, it is also the simplest and easiest to troubleshoot.
  10. Mizs Faa
    Nov 25, 2015
    11
    This is my sample circuit for arduino to solenoid. In case there is incorrect for connection let me know
    Thanks!
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    Are you going to tie the emitter of the 4N35+the source of the NFET to the Arduino GND? If so, there is absolutely no reason to use the opto-coupler.
    The biggest benefit of using the opto-coupler is to reduce the possibility that the inductive spike from the solenoid will couple into the Arduino, causing problems with spurious resets or noise in analog circuits. To make that work, you cannot tie the emitter of the 4N35+the source of the NFET to the Arduino GND; they must be kept separate, which requires that the Arduino power supply and the solenoid power supply share no other common connections; i.e. they be completely galvanically isolated from each other...
  12. Mizs Faa
    Nov 25, 2015
    11
    Thanks for the idea but my leader asking me to use optocoupler in the system/circuit. Is my sketching circuit for voltage supply im connecting same source with solenoid and arduino? sorry if i miss that part.
    Btw thanks :)
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    Why do you force us to go to an advertising-supported website to see your image? (Post them here).
    There are a lot of problems with your posted opto-isolator circuit:
    How much current does the opto's collector have to sink to turn off the NFET ?
    What is the opto's Current-Transfer-Ratio? (Download and study its data sheet).
    Can the Arduino port-pin source enough current to drive the input side of the opt0?
    What happens when the NFET turns off?
  14. Mizs Faa
    Nov 25, 2015
    11
    I have read the comments at another post. Sorry about the second post because I thought need to post other post. As I told before i have lack of information in electronics design.
    Btw, MikeML post its really insult me by "Besides, the TS is trying to get us to do work that she should be doing as a student. It should have been posted in Homework forum, not either of the two forums she has posted it. So far, her circuit is totally what the members here have fed her..." What the mean of members here have fed her?
    As I know, I only take advice from MaxHeadRoom for the Logic Mosfet in my circuit. Other than that is my own design.
    I need help someone to help me how to read datasheet as I am lack of knowledge about that since my background is in networking. As my project in mechatronic. Two new thing to me for blend together. If someone cant help please do not insult me.
    I am please to learn from you maybe any tips to get info from datasheet. two weeks im try to learn how to read the datasheet (first time).
    thank you to the comments, Im really appreciate those who try to help me. Im sorry because im struggling to learn this new thing.
