Solenoid time constant
Discussion in 'Physics' started by JardaK, Mar 20, 2015.
  1. JardaK
    Mar 20, 2015
    I have a small problem.
    Solenoid has a resistance of 14.2 ohms and an inductance 0.056H is connected in series with a resistance 2.2Ohm
    Thus calculated is the Tau = L / R = 0,056 / (14.2 + 2.2) = 0.0034s
    But the measured value is 0.02s
    The measurement is done on an oscilloscope for resistance.
    Source is a classic laboratory.
    If I measure only air-core coil corresponds to the time constant.
    How is it possible that tau is based on much more?
    Solenoid Type:
    Code (Text):
    1.  http://docs-europe.electrocomponents.com/webdocs/001b/0900766b8001b732.pdf [/ code]
    2.
    3. Thank you for your response.
  2. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Did you measure with the plunger extended or retracted? Plunger position will probably have a significant effect on inductance.
    Edit: I don't think you should count the 14.2 Ohms as being in series with the coil when calculating Tau. So Tau = 0.056/2.2 = 0.025 s
  3. JardaK
    Mar 20, 2015
    Why?
    A formula please?
    Coil having no core has a smaller inductance. This coil inductance and resistance 0.012H and 14.2Ohm
    0.0012 / (14.2 + 2.2) result corresponds approximately
  4. studiot
    Nov 9, 2007
    5,005
    515
    Where did the inductance value come from?
  5. JardaK
    Mar 20, 2015
