I'm trying to improve an existing device which uses a motor to move a plunger up and down at high speeds. The device uses a rather simple design which mechanically converts the motor's rotation into reciprocating action. The problem is that it vibrates a great deal in the process.
I was thinking to use a solenoid to replace the motor in producing the up and down movement. I don't know much about solenoids and have the following questions:
1) The original device works between 500 and 1500 strokes/min (roughly between 10 and 30 per second). Using a timer or similar circuit I can reproduce this frequency but will the solenoid take it? Are solenoids designed to withstand such high frequencies? Will it break or burn?
2) Can solenoids produce enough force for applications beyond valve closing? To get an idea of what kind of force I'm looking for I would say it should be enough to break thick-ish glass or play pool with!
3) If the spring of a solenoid is removed can the actuator be moved back and forth by reversing polarity?
Thanks for your help.
