solenoid push button
Discussion in 'General Electronics Chat' started by praondevou, Nov 14, 2011.
  1. praondevou
    Thread Starter AAC Fanatic!
    Jul 9, 2011
    2,936
    489
    I'm looking for a push button with an integrated coil. Pushing the button would move a magnet inside the coil and therefore create a voltage.
    I'm sure it exists somewhere because wireless light switches exist that don't require batteries nor wire connection. I'm just not sure if they are commercially available as single units.
    I could build one with a small relay coil or similar, but it's kind of unprofessional. Has anyone seen something like this?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Where? Anyone I've seen required batteries or was hooked to the house wiring.
    The amount of energy from just pushing a single push button is very..very..very small.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    http://www.adhocelectronics.com/Products/Wireless-Lighting-Control
    Look under "How it works". I want something similar but smaller, as small as possible. I need only about 6mA for 10ms at 3.6V.
    I did some tests with a vibration motor from an old cellphone but I get only about 100mV for a 2 to 3ms. I could pass it through a boost converter (energy harvester for example) and charge a capacitor. But I would like to activate my circuit with a single button press.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm thinking that they could be using a piezo element instead of magnetic.
    Piezo elements can be quite small, and just need a sharp impact to generate electricity for a moment.
    http://en.wikipedia.org/wiki/Piezoelectricity
    For example, take a look inside one of those butane lighters used for starting BBQ's.
    praondevou likes this.
  5. Feign
    Mar 30, 2009
    50
    The mechanics for what you want can be found in a BBQ lighter, or any with a spark starter. But then your light switch turns out with a bit of a Harry potter feel, due to the layout of the device. If you can fabricate a rocker switch to opperate two of them it would be more 50's TV clicker.
    I assume the commercial remotes use a jewel thief, and button cell
  6. Feign
    Mar 30, 2009
    50
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Closest Patent I could find Uses a piezo element to power the RF momentarily, but this is for automotive applications.
    I could see it being modified for home use if the receiver has enough sensitivity.
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
  9. praondevou
    Jul 9, 2011
    2,936
    489
    LOL, I liked that. :rolleyes:
    Thanks to all, I read about the Piezos before but from what I understood they put out peak power at their resonance frequency.... Not sure how I could get there with a single button press. Will do some more research in this direction.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you plucked a piezo like a string, it would resonate at its' natural frequency.
  11. praondevou
    Jul 9, 2011
    2,936
    489
    The piezo I found that is affordable puts out 3.4nC at 2mm deflection. I need more like 20uC to power a transmitter for 10ms.:(
    I will buy one anyways to do some testing.
  12. colinb
    Jun 15, 2011
    351
    35
    It looks to me like that switch has a large coil that must be involved in generating power. “Micro Generator”, they say.
    SgtWookie likes this.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yep, certainly is...
    wow, there sure are a lot of parts on the board. Good candidate for a VLSI.
  14. thatoneguy
    Feb 19, 2009
    6,357
    718
    The inductor and room needed for the SAW to build and transmit through antenna wouldn't reduce it much below the size of the transformer, though. I think it would surely fall into the category of "nanopower", through. Assuming it uses one inductive spike to charge the cap and spit out it's ID code just as quick with an of or on, then be out of power until it is pressed again.
