Hello all,
I am working on an artwork that takes the form of a pendulum operated by a 12 dc volt solenoid.
Solenoid Link here:
http://www.hobbytronics.co.uk/solenoid-12-36v?utm_source=google&utm_medium=googleshopping&utm_campaign=googlebase&gclid=COWFwcPk2LwCFYUIwwodRgYAUg
a reed switch and magnet on a moving paddle attached to the pendulum arm (see attached image)....
All works well for about 20 mins then the the reed switch contacts fuse together and the pendulum stops. Blue sparking starts to occur prior to the fusing together suggesting an overload of some sort. I am not too knowledgeable about electronics so does anyone know of an simple elegant way of making this thing work without fail? A simple circuit i can build.
I am not sure about the value of the reed switch but it is about and inch and a half long and i think, but am not totally sure is rated at about an amp??
I am waiting for a video of the pendulum to upload to give you a better idea of how the pice works, will post presently..
here it is : http://vimeo.com/97652817
all the best
Derek Ogbourne
Solenoid Link here:
all the best
Derek Ogbourne
