Solenoid driver suggestion
Discussion in 'The Projects Forum' started by peyro, Aug 28, 2010.
  1. peyro
    Aug 28, 2010
    I need to build a 4 port solenoid driver. The solenoids operates at 24VDC, 54Watts, which is if not wrong around 2.2amps. Could you kindly suggest whether to use a MOSFET or bipolar transistor and any reference part for that? The driver board needs to be isolated, so 4N35 optocouplers are to be used as well. Thanks in advance for any suggestion!!
  2. windoze killa
    Feb 23, 2006
    605
    24
    Personally I would use transistor switching relays. Provides the isolation you need as well.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    True, you can find solid state relays in the lower voltage/current range at fairly reasonable prices nowadays.
  4. windoze killa
    Feb 23, 2006
    605
    24
    I didn't actually mean solid state relays. I meant transistors turning relays on and off. I forgot an "s" on transistors. Makes much more sense when all the letters are there. :D
    Being of the old school I much prefer real relays that you can actually hear the click from.
  5. peyro
    Aug 28, 2010
    Hello thanks for suggestions!! But I have to switch around 3amps current with a frequency of one every 10 seconds in the worst case. So it seems to me that a normal relay mechanical capacity may be exhausted quick. What is your opinion?
    peyro
  6. BMorse
    Sep 26, 2009
    2,675
    234
    I would stick with a MOSFET, perhaps an IRF540 or similar.....
  7. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    I agree with Bmorse. It would be easier for the 4N35 to drive a MOSFET gate than a transistor base since speed doesn't seem to be an issue anyway. Use a diode across the solenoid to suppress the back emf.
    Regards,
    Ifixit
  8. John P
    Oct 14, 2008
    1,638
    225
    I suppose now MOSFETs are so cheap you might as well use them. But plain old bipolar transistors would certainly do the job.
    Actually I claim that driving a transistor base uses fewer components than a MOSFET gate--as long as it's a Darlington transistor. Just have the collector of the isolator go to the +24V rail, and the emitter to the transistor base. With a MOSFET, you'd need an additional pulldown resistor to turn it off, but with a Darlington, that's likely to be built in.
    See TIP102, 39 cents at Jameco:
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_32977_-1
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might consider something like a DRV102; Texas Instruments makes them.
    Product page and datasheet: http://focus.ti.com/docs/prod/folders/print/drv102.html
    The idea behind these drivers is that they provide a high initial current through the coil to ensure that it engages, and then a lower hold current. This will help keep your electric bill down in the future.
