Solenoid driver DRV102T problem
Discussion in 'General Electronics Chat' started by softbuster, Feb 5, 2010.
  1. softbuster
    Feb 5, 2010
    10
    Hi all
    I'm trying to operate simple solenoid valve using Camozzi U72 solenoid
    www.camozzi.com.cn/download/product/ENG_2_2_35.pdf
    It operates in 12V (5W) and has 3 inputs
    And I'm using DRV102t solenoid driver
    http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=drv102&fileType=pdf
    DRV102 output pin 6 shows nice PWM output variating from 0 to 12V, but actual solenoid load pin never goes below 6,8V. So the PWM output variates between 6,8 to 12V in load output
    why the PWM load never goes 0V ? I guess that my diode selection could be wrong
    Or is it possible that DRV102 could not driver Camozzi U72 ? (I doubt)
    Thanks in advanced.
  2. mik3
    Feb 4, 2008
    4,846
    63
    The 1N4008 diode is a rectifier diode, thus it is not designed for high switching frequencies. Replace it with a schottky diode to reduce the forward voltage drop too.
  3. softbuster
    Feb 5, 2010
    10
    I Replaced IN4008 with IN5822, but still the load PWM variates from 6 - 12V...
    Is the schottky IN5822 correct choice to drop forward voltage ?
    I'm using another IN5822 fron output to load as well
  4. softbuster
    Feb 5, 2010
    10
    Still I can't get my solenoid to work properly....
    The PWM in load connect, as well as in DRV102 pin 6, is variating between 6-12V.
    What should I do to make the PWM variating 0-12V and to get the solenoid working ?
    Should I add some pull down resistors ?
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    What is your intention with the solenoid?
    As far as I can see the solenoid is only for open and close purposes.
    Greetings,
    Bertus
  6. Duane P Wetick
    Apr 23, 2009
    408
    19
    The solenoid data is a little confusing...12Vdc solenoid, 4W.= 0.333 amperes; @ 5W, I = 0.416 amperes. Minimum impulse is 18 mSec., so you will need a high current driver transistor, 1/2 amp. (min). The fact that the output never goes below 6 volts is a question mark? Is that zener diode clamping the output voltage level to 6 V? Just use a standard
    Silicon free wheeling diode across the coil, 1N4001. A N-Mosfet should work here, or a darlington NPN.
    Cheers, DPW [ Everything has limitatons...and I hate limitations.]
  7. softbuster
    Feb 5, 2010
    10
    Solenoid should control air pressure to user selected rate. Pressure control should be quite linear. And that's why PWM controlled solenoid is needed. There will be D/A controlled PWM duty, but at this moment I just try to get the correct PWM load voltage levels to solenoid.
    Without solenoid, the PWM output is perfect, but when solenoid is connected, the level changes to 6-12V and solenoid won't work
    DRV102T application notes only gives a hint for series diode and flyback diode connections, but .. ... it just won't work
    The schematic should follow the DRV102t application circuit and I added two schottky diodes to protect over voltages.
    Any ideas ?
  8. softbuster
    Feb 5, 2010
    10
    Could I connect one of the following diodes (i'm out of 1N4001 today):
    1N4148
    1N4007
    1N5408
    1N5822
  9. Duane P Wetick
    Apr 23, 2009
    408
    19
    Look at the min. interval required to energize the solenoid; 18 msec. does the PWM output have this capability? Any impulse shorter than this will do nothing.
    Cheers, DPW [ Follow the money]
  10. softbuster
    Feb 5, 2010
    10
    DRV102 has 24kHz internal PWM, so it seems that the impluse (on-off-on) period is too short for that solenoide.
    But it is interesting that this chip is dedicated to drive solenoids.
    I tested the circuit without PWM output, just setting 0 to input pin of DRV102 and solenoid load pin stays in 12V. So the same problem with this chip still exists.
    Do you have any other solutions to drive that solenoide wih 3.3V logic ?
    Maybe IRF540 to control solenoide and some bipolar to control IRF540 and taking care that 3,3V logic ?
    Could you list all components which are needed to drive 3,3V solenoid circuit ?
    It would be a great to have a list before going shopping. Thanks a lot
  11. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    In my opinion the DRV102 is for proportional valves.
    You could make your own PWM with a much lower frequency (say 1 Hz).
    This would let the valve "rattle" at a much lower speed and have an out put proportional to the percentage of the PWM.
    Greetings,
    Bertus
  12. softbuster
    Feb 5, 2010
    10
    Maybe you are right that DRV102 is for proportional valve control.
    This chip seems to be a very rarely used and I just heard that this could be a good chip for my application.
    What could be the best solution to drive such a solenoid application ?
    Any reference circuit diagrams ?
  13. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  14. softbuster
    Feb 5, 2010
    10
    Thanks guys,
    Just need a quick review of my MOSFET solenoid driver before going component shopping
    Is this okay ? Or do I need some more protection like caps and diodes ?
    The idea is that MOSFET is controlled by bipolar, which reverse the logic
  15. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    I would make the following changes, see picture:
    Driving the input and mosfet a little harder.
    Greetings,
    Bertus
  16. softbuster
    Feb 5, 2010
    10
    Thanks a lot.
    Would you also give a short explanation changes you made ?
