solenoid driver circuit
Discussion in 'The Projects Forum' started by bomrat, Feb 8, 2013.
  1. bomrat
    Dec 13, 2009
    25
    hi, i need to design a selnoid driver circuit. the voltage is 24vdc. and the selnoid is 24vdc. i need where the selnoid gets 24vdc and then falls off to 8vdc.
    thanks
  2. tshuck
    Oct 18, 2012
    3,531
    675
    I'm not sure I follow:confused:. Come again?
  3. crutschow
    Mar 14, 2008
    13,505
    3,382
    Are you saying you want to energize it with 24vdc and reduce it to 8vdc to hold the solenoid in?
  4. tubeguy
    Nov 3, 2012
    1,157
    197
    What current does the solenoid draw at 24V ?
