This means he can use full-wave rectifier and smoothing capacitor. 75V/0.707 = 106V roughly and subtracting the forward volt drops of two diodes per half cycle, will theoretically subject the coil to approx. 105V which should not overheat the coil.in the origional post, he said the solenooid is rated for 100 volts and the supply is 75, how would that cause overheating? the reduce current after pull in is used for when a solenoid is ran at or above its rated voltage.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
