Solenoid Design
Discussion in 'General Electronics Chat' started by JimBaity, Oct 29, 2012.
  1. JimBaity
    Oct 29, 2012
    5
    Hi:
    I am wishing to build a solenoid not to exceed three inches in diameter. It will operate on 24Volt DC provided by 2=12 volt automotive batteries. I need to produce 6-8 pounds ot thrust, a distance of 4 inches with a duration of 1 second. Can it be done? If so please help me with this project.
    Need to know coil details, wire size, turns. Any and all information which would help me make this unit.
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    This would require a mega-monster solenoid.
    Godzilla would wilt at the sight of it.
    The worst of the parameters is the 4 inches- solenoids can produce high forces over short travel without too much trouble, but 4 inches is like the Grand Canyon for a solenoid.
    Another type of linear actuator perhaps?
  3. JimBaity
    Oct 29, 2012
    5
    Thanks for your reply. It has helped me understand what I can and can't do with this idea. My project is basically a solenoid motor, but giant sized to actually operate an old hit & miss engine by replacing the piston with a solenoid actuator inside the cylinder. Any sugestions?
    Again thanks
    Jim Baity
  4. PackratKing
    Jul 13, 2008
    850
    216
    :eek: re-inventing the wheel ?? Presuming you could adapt this hardware to actually work, what would be its end use............??
  5. JimBaity
    Oct 29, 2012
    5
    Only to produce a hit & miss engine which would rotate the flywheels through an unseen power. Batteries and controls would be mounted in a wooden box on which the engine would be mounted. The total stroke on the crank is 5 inches although I realize that power would not be necessary through out the complete stroke. The flywheels would provide some energy. The 2 flywheels weight about 150 pounds.
    Any more thoughts
  6. Austin Clark
    Dec 28, 2011
    409
    44
    Will a simple lever work? You could use a solenoid that moves less than 4 in but with more draw strength.
  7. JimBaity
    Oct 29, 2012
    5
    Excellent thought. I could pull the crank rather than push the crank. If I could get more draw strength than pulling strength then I will go that direction. I cant see where it would affect my flywheels in drawing rather than pushing.
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    You really want to do both, push and pull, to get double the engine output power from the same size solenoid. Solenoids can do both push and pull, especially if they have two coils.
    I'm not sure the project is viable, if it is like most hit and miss engines they are fairly heavy and might need a horsepower or so just to run? A hp is 750W and the solenoid will likely be activated for 20% of the time? That's 5 hp into the solenoid or 3750W, at about a 20% duty cycle.
    Your 24v battery will not like pulses of 3750W (that's 156 amps!) at a 20% duty cycle continuously, and all that is just to make it run, you might need double or triple that to try and use it for anything.
    A better option I think would be to remove all the reciprocating parts of the engine and just keep the main flywheel and output shaft, then drive it with a 24v DC motor and a nice efficient belt drive.
  9. JimBaity
    Oct 29, 2012
    5
    Thanks for your advice. I may be barking up the wrong tree with my idea. This may not be viable as you have indicated. I will find the power needed to rotate the 150 pound flywheels and then check back with you, if I may. Thanks again
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Please do, it's an interesting project. :)
  11. shortbus
    Sep 30, 2009
    4,086
    1,664
    Is this project meant to do actual work by a solenoid engine or just to make the engine rotate as a display?
  12. Bernard
    Aug 7, 2008
    4,231
    414
