I have a 120VAC solenoid control valve typically used for washing machines.
Goal: I want to open/close valve with a flip of a toggle switch.
Question: What (if any) support parts do I need to control this?
Concerns: I've never worked with solenoid valves so I'm not sure if it needs any supporting hardware.
Background: This is to control water changing system on an aquarium. Basically, I've split the water source (to the washing machine) with a "Y" adapter and I want to run the supply into a storage barrel. For now, I want to manually control it (so turn it off when barrel is full... automation will come later). Just need a temporary working solution.
For now, all I want is to have a properly rated toggle switch controlling the solenoid valve. Are there any problems with toggling a solenoid as if it were a light?
Additional concern/question: I plan to put this in a project box, drill some holes for the inlet/outlet/wires and then seal it tight with silicone. Just in case though, do you think it'll be necessary for me to add an internal fuse to it? I'll probably have it connected to a GFCI anyway.
Thanks,
Eric
Thanks,
Eric
