Solenoid control enquiry
Discussion in 'General Electronics Chat' started by semsemhts, Jul 10, 2016.
  1. semsemhts
    Mar 17, 2014
    15
    Hello every one I've a solenoid 24v dc and I want to have a continuous reciprocating move Forward & Reverse with adjustable speed regulator.
    Waiting for your help .. Thanks alot
  2. djsfantasi
    Apr 11, 2010
    2,911
    881
    First, if it's a simple solenoid, you can only control motion in one direction. In or out. Mechanical means are necessary to return the solenoid to its starting position*.
    Note that solenoids are relatively slow devices and current hungry. If you drive them with an astable miltivibrator, you will need driver circuitry to actually power the solenoid and protect the oscillator from back end.
    * there are dual solenoid devices for reciprocating motion.
  3. BobTPH
    Jun 5, 2013
    807
    121
    Tell us what you are trying to do. A solenoid sounds like the wrong solution.
    Bob
  4. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Usually a proportional valve is used for position and/or speed control of a cyclinder/solenoid etc.
    If hydraulics are not present then a motorized linear actuator might be the answer, you can achieve the motion you state in the OP.
    Max.
  5. semsemhts
    Mar 17, 2014
    15
    The application is :
    http://www.automaster-tw.com/productsDia.php?pn=1384
    which is pumping grease into a system using compressed air in the reciprocating move .. So I thought I can exchange the compressor with a solenoid making the reciprocating move I want ..
    thanks
  6. semsemhts
    Mar 17, 2014
    15
    well ,, Yes it is very simple solenoid just two cables , 24v dc
  7. semsemhts
    Mar 17, 2014
    15
    well , I want it to be powerful and fast maybe 10 times per min
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Use a simple motorized rotary to linear Piston for increased leverage over a straight solenoid/piston.
    Max.
  9. crutschow
    Mar 14, 2008
    13,509
    3,385
    That air operated pump likely generates a very large amount of force to pump grease and would thus require a very large solenoid.
    I agree with Max, that something like a screw driven linear motor would work better to drive the piston.
  10. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Crank method on the right.
    Max.
    BobTPH likes this.
  11. semsemhts
    Mar 17, 2014
    15
    Tanks alot max.
