Thanks, its doing crazy things on the graph can you send me all the rest of the files that worked already???
Thank you.
** never mind I fixed this....
Thank you.
You need to use reference designators, or I don't have a clue which transistor or resistor you're talking about. Reference designators, also called "labels" are like R1, Q3, C3, L1 etc.In the board I can see clearly that the resistor is between the emitter to base.
You might be wrong about what terminal on the SOT-23 part is the base, emitter and/or collector.But I might be wrong about the type of the transistor (NPN/PNP).
I don't think you had a straight-forward match for either transistor.this copy is "as is" it was easy to copy it, but I can be wrong about the transistors.
That's the minimum standard value that I calculated would be safe. It seems to work in the simulation, too.About R1 thank you I will change it to 0.036ohm.
It's for driving the gate of Q2.I am sure that the Q3,4 circuit is for driving the control pin from the uC.
Try some measurements.How can I be sure on this?
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Aaron Carman
