Solenoid Charge-up driver schematics
JK-FlipFlop
Joined Jul 5, 2010
111
I bought (for my Robot project) powerful solenoid driver, that charge up to 110v and discharge when the control pin goes high. The effect is very strong, The solenoid current is very high (about 15 amp) and this driver taking this current from the capacitors instead of the power supply (fat batteries) , therefore I didn't do it with simple H-bridge that cant supply such current.
here is all the data sheet I have from the manufacturer:
video: http://www.youtube.com/watch?v=e4--qDNGgQE
Manufacturer web (if working): http://www.curobot.com/modules/news/print.php?storyid=19
Somehow I destroyed this driver and its no longer respond to the 5v control pin (the white one), and always discharging without giving him 5v.
for fixing it I needed the schematics of that circuit board.
I asked from the manufacturer this schematics but he doesn't want to give me them, he wants me to buy a new driver kit (it cost 100$ and it's a lot of money) and I can't afford it. I have tryed to convince him but it doesn't help. I need schematics to fix it but also for my project post.
I have tryed to replace two of the power transistors by new ones but still the same problem.
Now I need you to give me tips and ideas how to figure out the schematics from the board it self.
(creating schematics for the driver).
I create an album of this driver for you could help me:
I can check any conections on the board just tell me which..
The name of the transistor is: 62N25C
The name of the voltage convertor (coil) is: coiltronics vp5-0155 46CH03
Datasheet of this coil voltage convertor : http://www.cooperbussmann.com/pdf/453f0091-4eeb-4ee7-b33c-b689416a62c7.pdf
I really need your help
Thank you.
SgtWookie
Joined Jul 17, 2007
22,230
The images you posted are not lit very well. It is very hard to take good photos of circuit boards. You must use very even lighting, or shadows and reflections will make it impossible to determine what one is looking at.
Your board seems to have flux or perhaps a clear coat over it. Try cleaning it with 90% or better pure isopropyl alcohol and an acid brush (nylon bristles).
Your board has two more transistors, Q3 and Q4, that look like they might be SOT-23 packages. You should look up the codes printed on them to find out what they are.
D2 might be shorted or open.
JK-FlipFlop
Joined Jul 5, 2010
111
Q3 & Q4 have very little codes on them I barely see them even with magnifying glass,
I think the code of Q4 is "MCD" or "MCE" or "MC0" none of them bring results.
about Q3 I cant see, its like the transistor melt on is surface and there is no code.
there is other way to figure out what are they?
thank you.
SgtWookie
Joined Jul 17, 2007
22,230
Well then, perhaps Q3 is defective.
Don't know what it might be though, other than a transistor or MOSFET.
You will need to try to construct a schematic from what's left of the circuit. Follow the traces around, see what components are connected by the traces, where power and ground connect, etc.
JK-FlipFlop
Joined Jul 5, 2010
111
I can check with multimeter the connections beteen components, it will take servel of hours. do you have any tips for constructing this schematics, where to start, Pay attention to which of the components...
thank you.
SgtWookie
Joined Jul 17, 2007
22,230
Why don't you start off with whatever your "power rails" are (what are they? +5v and ground?) and what your output connectors are.
JK-FlipFlop
Joined Jul 5, 2010
111
OK I will start with the input circuit or maybe all the lower layer.
Tomorrow I will post it, I will try to add the values of the resistors, I don't know how to measure the value of the capacitors but I will put their name from the board.
JK-FlipFlop
Joined Jul 5, 2010
111
Ok I constructed a schematic from this board from the lower side:
Please analyze this circuit and then tell me what to do next...
where to start solving in the upper side.
Thanks.
SgtWookie
Joined Jul 17, 2007
22,230
Are you certain that the connections to Q2 are correct?
You have the solenoid low side connected to the gate.
I think it should be connected to the drain of the MOSFET (pin 3)
Basically, move the current connection on pin 3 (drain) to pin 1 (source), the connection on pin 2 (gate) to pin 3 (drain), and the connection on pin 1 (source) to pin 2 (gate).
Q3, Q4, and R9/R8/R10/RR are supposed to be some kind of gate driver circuit, but I think you have the transistors turned around.
I would expect that part of the circuit to be some kind of emitter follower arrangement. I would also expect a low-value resistor to be between the transistors and the MOSFET gate.
If Q4 is an MMBT4401 (NPN), then Q3 would likely be an MMBT4403 (PNP).
JK-FlipFlop
Joined Jul 5, 2010
111
OK I probably mixed between the Q2 legs ( I know only collector,emitter and base) I guess its diffrent from the regular transistor. I will fix it.
The MMBT4401 is my guess I dony realy know which transistor it is, there is any way to check it?
thanks.
SgtWookie
Joined Jul 17, 2007
22,230
You look up the codes that are on the top of the SMD. If they don't cross reference to anything, you're kind of out of luck. They could be "house-marked" parts, which are meaningful only to the company that manufactured it.
SgtWookie
Joined Jul 17, 2007
22,230
That's somewhat better.
The gate driver circuit needs a lot of work.
R9 appears to be a 10k gate pull-down resistor; that's pretty typical.
It would be less confusing to just show one end of it connected to the gate, and the other end directly to a ground symbol. Wires running everywhere are distracting.
RR is not placed correctly. If SW1 is toggled, it would be between Vcc and GND, and not doing anything useful that I can tell. Perhaps it is supposed to be the base current limiting resistor for Q3.
I don't see yet how Q2 gets turned on. There doesn't seem to be a source to do that.
SgtWookie
Joined Jul 17, 2007
22,230
If the supply on the left goes to your cap bank and the supply on the right goes to 10v, then that would work. The 10k resistor keeps the MOSFET gate from "floating", which could destroy it.
Perhaps transistors Q3/Q4 are part of an oscillator circuit.
You haven't mentioned the supply voltage. I take it that you supply it with something like 10v or 12v, and it charges the caps to ~100v, and you then fire the solenoid by pressing the button. Right?
kubeek
Joined Sep 20, 2005
5,795
It is a control circuit for boosting the voltage using that transformer or inductor.
If the caps can get charged, you need to focus on the mosfet gate drive circuit. Most probably the problem is only a melted mosfet.
JK-FlipFlop
Joined Jul 5, 2010
111
Anyway I will need this board schematics for my project test, it's more important, therefor you are helping me constructing the schematics.
