Solenoid Charactaristics
abuhafss
Joined Aug 17, 2010
307
Hi
I am working on a solenoid powered from a 12V SLA battery and have a few questions:
1) Suppose the solenoid needs 5A to actuate, how can that current be reduced? By increasing the number of turns?
2) What will be effect of increasing the thickness of the coil wire?
3) If a solenoid is powered for longer duration, the internal resistance of the coil increases and thereby more and more current is drawn which causes self-heating of the coil. Can this be overcome using a fixed current supply?
MaxHeadRoom
Joined Jul 18, 2013
28,686
Presumably this is DC, in any DC electromagnetic device that has an armature such as a solenoid or relay, the current can be reduced after the solenoid has become energized due to lower energy required to retain it than it does to shift the armature or operator in the first place.
Max.
Bernard
Joined Aug 7, 2008
5,784
Re, Max, add a resistor in series with solenoid of a low enough value to keep armature pulled in, connect a capacitor in parallel with R, large enough to pull in armature when at full extention.
abuhafss
Joined Aug 17, 2010
307
So, if we increase the number of turns of the coil, the current drawn can be reduced......am I correct?
And the coil current can also be reduced (using a resistor in series) after it has been energized. Got it but, can you please show some practical schematic? Do we have to incorporate another relay to switch the supply thru resistor after the coil is energized?
34,428
Yes.
Bernard suggested how to do that with a resistor and capacitor. Note that the capacitor may have to be quite large to provide the initial 5A surge for the required time to pull in the solenoid. The value can be experimentally determined.
MaxHeadRoom
Joined Jul 18, 2013
28,686
There is an initial current to charge the capacitor that essentially shunts the resistor, once the cap has charged there is no more capacitor current, the resistor then comes into play to limit the current.
Max.
abuhafss
Joined Aug 17, 2010
307
Hmm, got it. Thanks for the explanation.
For this case, the required wattage for the resistor would be about 70W.......Correct?
And what should be the starting value for the capacitor? 1000µF/16V, 2200µF/16V, 3300µF/16V.........?
34,428
The wattage and resistance of the resistor depends upon how low a voltage the solenoid will stay pulled in after it is energized. For example, for a voltage drop of 6V @ 2.5A the power would 15W and you should use a 30W resistor.
I would start with about 10,000µF, 16V.
