Soldering two rings together
Discussion in 'Off-Topic' started by droggie, Dec 20, 2012.
  1. droggie
    Oct 21, 2012
    137
    I have two gold rings I would like to solder together. The only problem is I don't want to directly apply solder to the gold. I was thinking I could bind them together with some wire and just solder it. Does anyone have any ideas?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Take them to a jewler.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Typically you would use a gold solder with the same carat as the gold you are soldering and some acid or borax flux. Maybe just stack them and use ceramic bricks to keep the alignment. You have to be careful because the melting point of the solder is not much lower than the rings themselves. Then there is just cleaning and polishing.
    If you use a solder that isn't gold, it either won't work or stands a chance of spreading over the ring surface and then needing removing.
    A jeweller that does repairs will probably charge less than it would cost to get the solder and equipment.
  4. droggie
    Oct 21, 2012
    137
    After scouting various jewellers, the lowest price I could find was about $100. All I would need is gold solder. I have the rest of the equipment. I was just wondering if I could solder a clamp to hold them together.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think it would be better if you described your intentions and the end result a bit better. Different methods give different end products.
  6. Markd77
    Sep 7, 2009
    2,803
    594
    I used to use this place because it is fairly local, but they do international delivery:
    http://www.cooksongold.com/category_select.jsp?query=gold+solder
    You can probably find a more local supplier.
    Solder paste contains flux so is very easy to use.
    You can use iron wire to hold the pieces together:
    http://www.mjsa.org/publications/tech_sheets/tips_for_soldering_set-up
    A good gas torch is important so you can get the whole thing to the same temperature.
    Something like this is good:
    www.ebay.co.uk/itm/181039715608
  7. upand_at_them
    May 15, 2010
    246
    29
    Silver solder should work.
  8. Markd77
    Sep 7, 2009
    2,803
    594
    Silver solder will work, but it will flow across the ring surface and then need very careful filing and polishing to remove it. It would be easy to make a mess of the rings doing that, especially as the silver solder is harder than the gold underneath. With the right gold solder it's not a problem because the solder is essentially the same as the rings themselves so it just needs a bit of smoothing.
  9. maxpower097
    Feb 20, 2009
    795
    388
    Many Pawn shops here in the US do custom jewelry. Not sure if you got pawn shops or if they do jewelry though.
