Soldering to a Perfboard
Discussion in 'General Electronics Chat' started by dysnomia, Jan 21, 2013.
  1. dysnomia
    Jan 21, 2013
    So, I'm working on a project and I ended up just buying a cheap perfboard from radio shack without the copper pads. I made do with what I had and managed to solder most of the components but I'm having a hard time with IC sockets. Their leads are so short that i have very little room to work with and soldering them almost feels like an impossible feat at this point.
    Anyone have any suggestions on how to solder these, or should I just dismantle this and go get a perfboard with copper pads?
  2. kubeek
    Sep 20, 2005
    4,689
    806
    You could try using precision sockets instead of the "normal" ones, these have the pins a little longer.
    dysnomia likes this.
  3. dysnomia
    Jan 21, 2013
    Hm I'll look into those; I have these 8-pin headers I'm using for a different component kind of like these : https://www.sparkfun.com/products/9279
    Do you think if I get two of those I can perhaps put an IC in that? These were VERY easy to work with
  4. spinnaker
    Oct 29, 2009
    5,078
    1,179
    I have never had a problem with any kind of socket and perf boards. It could be the wire you are using. It might be too big.
    I use wire wrap wire. I stick the wire down the hole between the leg and hole and then solder. Of course you would need to take into consideration what current you are working with.
  5. dysnomia
    Jan 21, 2013
    Wait, so you shove the wire in the same hole that the IC Socket leg is in?
  6. spinnaker
    Oct 29, 2009
    5,078
    1,179
    Yep that is what I do. It helps to hold the wire in place while you solder.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Why do you use IC sockets? Most ICs are cheap.
    Copperless perf board is a curiosity.
    What do you call cheap? Small 5x7 boards cost me like 25 cents.
  8. spinnaker
    Oct 29, 2009
    5,078
    1,179
    I prefer to use sockets. Less chance of damage during soldering. Much easier to take in and out of circuit to replace and / or test.
    ICs aren't always cheap. Depending on the IC, it could cost upwards of $4.
  9. crutschow
    Mar 14, 2008
    13,501
    3,375
    Wirewrap sockets have long leads, similar to the 8-pin headers, which you can cut to the desired length for soldering.
  10. mcgyvr
    Oct 15, 2009
    4,791
    976
    Perfboard w/copper for soldering
    Perfboard w/o copper for Wire Wrap (bet most of the young guys don't even know what that is)
    I will choose Wire wrapping over soldering on perfboards any day.. For some reason its like a lost art now. But its one of the easiest/most reliable connections you can make.
  11. takao21203
    Apr 28, 2012
    3,578
    463
    I prefer SOIC adapters. Easy to remove an IC if neccessary. ICs are never damaged by soldering this is an urban legend.
    I have put ICs on PCBs and baked them for many minutes. No damage.
    Yes I used sockets, many years ago.
    When I need a "socket" these days, I make one from a small PCB piece, and row headers.
    OK yes GAL's need sockets but they are so out of fashion. And EPROMs. Yes I have GALs here and EPROMs (a few).
  12. spinnaker
    Oct 29, 2009
    5,078
    1,179
    I loved wire wrap. I worked on a production system that had both wire wrap and pcb the easiest to troubleshoot was wire wrap. I don't know if you can find the tool today. Don't know what happened to mine.
