Hi --
My Weller soldering tip wont hold solder anymore. It looks very damaged but I don't use it that often? Is it possible to repair this tip with Tip Activator? What causes this damage? How can I avoid it in the future?
I use non-leaded solder most of the time. I try to keep the heat as low as possible. When finished I coat the tip with solder and let the solder harden on it then put it away like that for storage. I use a sponge and filtered water and wipe off during soldering.
Thank you!
Thank you!
