Soldering Smoke Theory
Discussion in 'Off-Topic' started by Metalmann, Aug 4, 2013.
  1. Metalmann
    Thread Starter Active Member
    Dec 8, 2012
    700
    223
    I say the reason soldering fumes/smoke drift your direction, is because your body heat causes an updraft of heat, which causes the vacuum, (Filled with fumes); of cold air, to be drawn up your nostrils.
    As you solder, the fumes/smoke.... jump in to fill that vacuum left behind from the heat leaving your body.
    Thus, smoke up your nose.
    Same reason that a shower curtain sucks in at the bottom.
    What saith ye?;)
    I know......how profound!:D
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    I invented marijuana-filled resin core solder.
    Makes for happy soldering workers.
    Send me money and I will supply you with a sample.
  3. prymal
    Aug 3, 2013
    ^ That is such a good idea.
    Metalmann likes this.
  4. mak445
    Aug 3, 2013
    where can I buy some of that at ?
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    That sounds plausible metalmann but what about camp fire smoke? It follows you too, no matter what side of the fire you stand on, and that's outside in the wind.
    Metalmann, Robin Mitchell and #12 like this.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I suspect it has more to do with remembering the bad times more than the good ones. It is uncomfortable, and leaves a deeper impression.
  7. tubeguy
    Nov 3, 2012
    1,157
    197
    Would be a good place to open a Hot-Dog stand. ;)
  8. #12
    Nov 30, 2010
    16,704
    7,352
    For those who don't know, you just change the "rosin" core to "resin" core.:D
    Metalmann and shortbus like this.
  9. MrChips
    Oct 2, 2009
    12,636
    3,455
    Sorry. Close enough.
  10. Brownout
    Jan 10, 2012
    2,375
    998
    I love the smell of solder smoke in the morning.
  11. LDC3
    Apr 27, 2013
    920
    160
    Do I hear "Ride of the Valkyries"?
  12. monster_catfish
    Mar 17, 2011
    110
    107
    If it were possible for Robert Duvall to obtain copyright ownership of that famous line from the movie classic Apocalypse Now, he would have made a killing from its use over the years since.
    I sure have used various adaptations of that line more than a few times, including one version that is far too risque to repeat in a family oriented forum such as this one.
  13. WBahn
    Mar 31, 2012
    18,087
    4,917
    Bernoulli's Principle. As the wind goes around you it creates a low pressure region near your body and the smoke tends to move towards it to become entrained in the airflow.
    Metalmann, #12 and strantor like this.
  14. shortbus
    Sep 30, 2009
    4,096
    1,692
    On a serious note, isn't the reason for solder flux smoke due to the ionic nature of the flux? If the human body is of one natural polarity and the flux smoke is the opposite the body would attract the smoke. And the flux is ionic in nature, this is what allows it to 'wet' the solder joint. http://en.wikipedia.org/wiki/Flux_(metallurgy)
  15. #12
    Nov 30, 2010
    16,704
    7,352
    Interesting theory. I doubt that it is true, but I would like to hear form somebody that knows the answer.
  16. tubeguy
    Nov 3, 2012
    1,157
    197
    What about 'Magnetic Personality" ?
    Metalmann and #12 like this.
