Soldering Pen
Discussion in 'General Electronics Chat' started by cmartinez, Jan 19, 2007.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,698
    2,790
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    See if one of the wires is connected to the tip. It's usually done for ESD protection and is tied to earth ground.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If there were only two wires, the resistance in the both wires would be added to the element resistance (as far as the bridg is concerend). The change in bridge voltage as a function of temperature change would be reduced.
    By adding a third wire, the entire lower half of the bridge can go into the soldering iron housing. Each side has a wire going back to the rest of the circuitry, so conductor resistance cancels out. Delta V per Delta degree is thereby maximised.
