Soldering leads on laptop cells
Discussion in 'General Electronics Chat' started by Lectraplayer, Apr 3, 2015.
  1. Lectraplayer
    Jan 2, 2015
    77
    5
    What are ths main considerations for durably soldering leads onto a lithium ion laptop cell? I know this can creats a pyrotechnic acid bomb if you get the cell too hot, and lithion ion can be about like napalm. While a battery holder would be best, the 4/3 A size I see quoted as a laptop cell is hard to find locally sourced, and I don't want to order an item I intend to use commonly.
    Note: Do not solder directly to any battery cell unless you know what you are doing! Batterys can, and sometimes do explode, and the results are often horrid.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    There is no way to make this operation safe.
    Is your life worth nothing to you?
  3. GopherT
    Nov 23, 2012
    6,339
    4,083
    They are not soldered, they are typically welded with a very hot, small and, therefore, short contact time that does not heat the contained lithium much.
  4. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Well, actually, a pyrotechnic alkali bomb, but nobody's keeping score:D
    With officious regards
    HP
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    If you are motivated and have several packs to do, you can build your own tab welder. I built one based on the description in this link: http://www.philpem.me.uk/elec/welder/
    Here's a example of a 2S pack of RCR123A LiFeP rechargeable that I made this morning:
    The little teflon washer is something I have been adding since NiCd days. It is intended to protect against any short between the nickel strap and battery case. In this example, I used 1/8" nickel straps, 0.005" thick.
    John
