Soldering Iron modification help
Discussion in 'General Electronics Chat' started by Adamf001, Aug 12, 2013.
  1. Adamf001
    Sep 5, 2011
    67
    Hi Guys,
    i have a 50w variable temp soldering iron like the one below
    http://www.maplin.co.uk/50w-solder-station-35016
    The only problem is that it seems to have stopped working, :(
    one of the parts is damaged and i cant get to the circuit board....
    I was just wondering, correct if i'm wrong (I probably am) but can I not just connect the soldering iron strait to mains? bypass the variable temp function (which I can do without until I buy a new one) the only problem I see with this is that there is now way to regulate the current, will i just keep blowing fuses?
    what do you guys think?
  2. Metalmann
    Dec 8, 2012
    700
    223
    Do not connect to mains.
    According to some of the reviews, that iron doesn't last very long.
  3. Adamf001
    Sep 5, 2011
    67
    yea its shame, its not a bad little iron, do you suggest any?, is it worth getting one that changes temp? personally I don't see the need
  4. Metalmann
    Dec 8, 2012
    700
    223
    Check out some of the Hakko models.:cool:
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    It isn't changing the temperature what's important, it's that the temperature is regulated to the optimum value.
