I am trying to solder four 28AWG wires onto a USB PCB. The PCB has four plated thru holes. The board is about .095" thick and I am using lead free solder @ 650 degrees F with a HAKKO FX951 and a heavy tip. I cannot get the solder to flow all the way through the thru holes with out having the wire insulation melting back up the wires. Will I need to preheat the boards? Thank you.
Steve55
Steve55
