soldering headphone cables
Discussion in 'General Electronics Chat' started by jut, May 13, 2008.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    Hello everybody,
    I'm repairing headphones for a friend; the right channel keeps dieing because of broken connection within the plug. So I cut open cable, stripped it back and found some strange wire. The wire is wrapped around what appears to be very fine strands of cloth. And to make matters worse, the wire, which is stranded, has, I think, an enamel coating. When I tried to tin the end of a wire, solder would not flow onto it. Has anybody worked with this stuff?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, it's a kind of tinsel used for low power applications. It will not solder unless you get very lucky. You may be able to make repairs with conductive paint, the kind you get for reworking PCB's.
    Probably cheaper to get new headphones.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Jeez, I hate that stuff. The only success I've had with it is to use a bit of xylol to dissolve anything not copper. Messy, smelly, unpleasant, and downright not fun. Even then, there's only a tiny thickness of massively misbehaving stranded copper to solder.
  4. jut
    Aug 25, 2007
    224
    So I ended up sanding the wire with emery cloth to remove the enamel coating and expose the copper. Even then it did solder easily.
    I also tried soaking the wire in de-natured alcohol for 1 hr, but that didn't do crap.
    Thanks for replying.
