Soldering Gun History
Discussion in 'General Electronics Chat' started by Metalmann, Mar 22, 2013.
  1. Metalmann
    Thread Starter Active Member
    Dec 8, 2012
    700
    223
  2. tshuck
    Oct 18, 2012
    3,531
    675
    I used to have that same soldering gun that's pictured!
    Good read, I had no idea...
    Metalmann likes this.
  3. gerty
    Aug 30, 2007
    1,154
    304
    I still have mine
  4. BReeves
    Member
    Nov 24, 2012
    412
    64
    Good find..
    8th grade, 1959. All I wanted for Christmas was a Weller soldering gun and thankfully my folks came through. The original disappeared while I was in the Navy but have owned at least one Weller gun most of my life. Presently have 3 of the silly things, 1 8200 and 2 D550's. Not something you want to solder surface mount chips with but they are hard to beat for a quick job tinning wires or soldering stuff large enough to handle the heat.
    Back when we only dealt with tubes and large components a Weller gun was all you needed. I do really miss the simpler times.
  5. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I think mine is the Radio shack version. It is still around here somewhere.
  6. ErnieM
    Apr 24, 2011
    7,433
    1,623
    My Dad had this Weller. I've had a few of their pencil irons.
    Weller is a classic company you can trust for quality products.
  7. Metalmann
    Dec 8, 2012
    700
    223
    I bet it's been 4-5 years since I brought out the soldering gun.
    After reading that, it makes me want to go fire it up, just for old times sake.:D
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I still have my Weller gun. I had previously owned a Wen gun.
    This product apparently had a very short life. Wen started making the guns in 1951. Weller won a patent infringement case against them in 1954. They also won an appeal of that judgment in 1956. I'm assuming that Wen stopped manufacturing their guns about that time. I think I must have acquired mine in about 1955. It was a nice little gun, and, being smaller, was easier to use in tight spots. Unfortunately, mine did not survive being dropped on the concrete garage floor many years ago.:(
  9. Metalmann
    Dec 8, 2012
    700
    223
    I used to have a Wen, too. Can you repair it?
  10. Ron H
    Apr 14, 2005
    7,050
    657
    My Wen broke like 50 or more years ago. I glued the case back together, and it still worked. Looked like hell, though. I can't remember why I finally got rid of it. I suspect it was because the tip burned out, and no replacements were available.
  11. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Bought in the '60s which means.. I'm. OLD. Still use it occasionally when a lot of heat is needed fast e.g. old terminal strips.
    The other tip is for cutting plastics etc. The black stuff on the attached tip is when I didn't bother to change tips before cutting plastic, etc. The lightbulb is not standard. It came with a 222 with the focused lens. I liked this one better.
