solder wire calculation tips for production
Discussion in 'General Electronics Chat' started by JPBHATT, Nov 8, 2011.
  1. JPBHATT
    Nov 8, 2011
    Dear all Respected Member
    I require a standard formula for how i calculale the actual consuption of solder for electronics product during production.
    Regards
    jpbhatt
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    When you say "During Production", are you referring to paste flux+solder used in surface mount, which is the majority of mass production today.
    The other method is wave soldering for all through hole parts, though the number of devices mass produced with this method is reducing rapidly, mostly appliance boards and other simple line powered circuits where size isn't an issue.
    Trying to get an exact value as milligrams of solder per connection will be near impossible for soldering iron+spool of solder, as each joint can vary greatly.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    Simply ask purchasing. There is virtually NO way to calculate it. So just look at actual consumption numbers from purchasing. They know exactly how much/when they buy it.
  4. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Buy two units, either spools for hand soldering, jars of paste, or bars of solid for wave soldering. Make the best guess of how much a unit should be.
    When first unit is used up, buy another.
