solder iron maint.
Discussion in 'General Electronics Chat' started by PackratKing, Jan 10, 2014.
  1. PackratKing
    Jul 13, 2008
    850
    216
    This, from an old-timer, that did a ton of sheetmetal work, and soldering joints in ductwork... long before the likes of OSHA...:eek:
    Our soldering " coppers " were heated in a small gas-fired furnace, until enveloped by the " Green fire " indicating they were up to proper temp. Then cleaned and tinned when necessary by rubbing on a block of Sal Ammoniac. [ google ]
    NO soldering copper ever lasted forever, and we never had anything I saw that was plated...
    The fancy-schmancy ones were electric, and they were plated... but the cord was a total PITA
    So I am wondering if a block of Sal Ammoniac might be a boon to those using their soldering tools a lot... or has this been relegated to the era of dinosaurs...:D like they are trying to do with lead alloys...
    Note that fumes must be vented to outdoors, as S/A produces some rather acrid, and likely unhealthy smoke...
  2. #12
    Nov 30, 2010
    16,704
    7,352
    Arrgh. I've been stricken with a nostalgia arrow. :D
    I bought a block of Sal Ammoniac when I was 10 years old. Only later found that it was useless for electronics work. :(
    The best part? I was gathering the tools and equipment for my future by the time I was 10 years old.
  3. PackratKing
    Jul 13, 2008
    850
    216
    Please explain... I have lost track of my S/A in the obligatory shuffle of my " shop " to other quarters, and was going to get another... what nixes it for electronic work ???
  4. #12
    Nov 30, 2010
    16,704
    7,352
    It's a salt with a Ph of about 5 (acid). Leaving it on a circuit board would be similar to allowing salt water to dry on the board.
  5. PackratKing
    Jul 13, 2008
    850
    216
    OK... That makes perfect sense. Now that I think of it, our boss had us wipe the ducting joints we had just soldered down with a terrycloth rag and a bi-carb solution... Thanx much...:D
  6. atferrari
    Jan 6, 2004
    2,668
    784
    When I was a kid (60 years ago, appr.) IIRC, seen someone, with a huge sodlering iron, using that salt. Maybe a plumber?
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    It was standard equipment on the benches where they made all those hand-wired tube radios - but that may be as long ago as when they cadmium plated the component leads to make them more solderable!
  8. #12
    Nov 30, 2010
    16,704
    7,352
    Ah cadmium. I remember it well. Mossy cadmium used in chemistry class to make some kind of gas. Unfortunately, I went into electronics and forgot most of the chemistry :D
    Or was that mossy zinc?
    Darn senior moments.:(
