I plotted the output of a solar battery to show the need for a DC-DC C [ direct current to direct current converter ]. As the graph shows ,max power will occur when solar is loaded down to 28V @ 20.8A = 582W which is about half power for motor. Solar directly connected to motor might load solar to close to 28V, now at 28V , battery can supply current,bringing up motor voltage, which reduces power from solar, so we raise solar V with converter. Limit battery current to 1/2C, to make 2hr @ 10A. Now is battery V high enough to supply current ? Quite a ballancing act.
On test: peak power 886.2 mW, 76mA, 11.7V scalled up to full-sized collector .
