I have a solar panel with controller and inverter and a couple of 6 volt batteries powering lights in my shed/shop. To run my large equipment, I use a generator. I wire these two sources through a 3-way switch so that I don't try to use both at once. While hooking up a new inverter I noticed that, with the generator running, I got 50 volts AC into my inverter. Apparently, the 3-way switch didn't isolate power from my generator. Does this seem strange to anyone else?
