Hello all my first post on this forum and any forum for that matter, so please excuse me if I make any school boy errors, or simply asking a silly question!
I wanted to gain an understanding into the phase differences between my domestic voltage and current supply as I have a 4KWsolar PV installed. I hooked up a current clamp round the live cable going into the fuse box to observe the current sine wave on the oscilloscope. When the sun is down I notice that both the voltage and current are very much in phase. As expected, during sunshine (as long as supply > demand) I see that the two sine waves are 180 degrees out of phase, thus producing negative power again as expected when supplying the grid. The current sine waves amplitude grew and shrank according to sun light intensity, and if I turned on the kettle for example to draw all solar power available as well as extra from the grid then I see that the sine wave shifts back to be in phase with the voltage. All this is as expected, and I understand the principles (to a very basic degree!).
BUT!! When I look at the voltage and current waveform supplied to a specific load e.g. my 2KW heater, then I dont understand why the voltage and current are always both in phase regardless of whether or not the source of power is from the grid or from the solar PV?
i.e. how is it that a 180 phase shift PV supply, then appears in-phase at the load?
(I guess this begs the question therefore, is the grid voltage and current out of phase but appears in phase at the load i.e our homes for example)
