Solar Tracker
Discussion in 'The Projects Forum' started by sunwarrior1993, Nov 21, 2013.
  1. sunwarrior1993
    Nov 20, 2012
    Good day, everyone.
    I'm finishing high school this year, I have to develop a project to finish my technical course (Electronics, Automation and Computer Science).
    My project is a Solar Tracker, with the help of my professors we'll decide if have the chance to insert the X and Y axis for the solar panels.
    Let me break it down:
    - 6 solar panels, each produces 1.5V, that gives a total of 9V.
    - A 9.6V Ni-Cd battery pack will be used to store power, for further experiments in robotics or even powering other devices.
    - The battery can be charged by building a Ni-Cd battery charger.
    The charger circuit that my professor shared with me has a LM317 Ajustable Voltage Regulator.
    However, I'm concerned about the voltage regulation because I won't need it, I suppose.
    And also about the energy production, can 9V charge a 9.6V battery in DC?
    Any help or guidance will be deeply appreciated.
    Thank you :).
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    The open circuit voltage from the panels (when in bright sun) needs to be about 1.5X to 2X the open-circuit voltage of the batteries you are trying to charge. Only other option is to connect the panel output to the input of a step-up Switch Mode Voltage Converter whose output is high enough to charge the batteries. NiCads are charged with a constant-current, but the voltage required will need to go as high as ~12V
    Read how to charge NiCads (and NiMh) here.
    sunwarrior1993 likes this.
  3. wayneh
    Sep 9, 2010
    12,379
    3,234
    I agree with Mike - you'll need a DC-DC converter to boost the voltage. You can find them cheaply all over e-bay. On the upside, this is more efficient than the LM317 voltage regulator.
    Without the boost, the only way you can charge the batteries is to use a switching arrangement whereby you charge the batteries in parallel but then switch them to serial to supply the load. Since your cells are in a pack, this may not be an option.
  4. donpetru
    Nov 14, 2008
    186
    25
  5. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I'm puzzled. Your project is a solar tracker, but the details given and your question are about battery charging ??
  6. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Typically once one builds a solar tracker they attach it to a solar panel.
    One application of solar panels is to charge batteries.
    OK?
  7. sunwarrior1993
    Nov 20, 2012
    MikeML, wayneh and donpetru: Thank you for the information, I will definitely check out the link and the PDF file. :)
    Alec_T: Yes, my main issue was about the battery charging, but now I understand that I need a higher voltage than the input voltage produced by the solar panels, to charge the battery pack.
    I started to do some research about the Boost Converter.
    Again, I appreciate your help.
    Best regards.
