Solar system Batteries ??? 's
Discussion in 'General Electronics Chat' started by Desert Sunshine, Mar 12, 2009.
  1. Desert Sunshine
    Mar 12, 2009
    My solar panels are wired and installed.. I need to know how to hook up my battery bank. I'm using (4) 6 volt batteries, hooking them together to make (2) 12 volt batteries.. Connecting a solar controller for charging, a then connecting them to a power inverter.. See the attach diagram..
    Someone please let me know if this wiring is correct.
    If NOT please show me how to wire them... [​IMG] Thank You...
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    :eek::eek::eek::eek: If the batteries on our solar system run down, we're ALL in deep doo doo! :D
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Not to worry. Last I checked, our solar system runs on a nuclear plant.:D:D:D
    Desert: your diagram is correct.
  4. italo
    Nov 20, 2005
    205
    Most people don't understand that batteries are not created equal therefore to add them in series develops no problem however in parallel there is a problem. if one is not fully charged or weak the the other battery will try to compensate for the weakness making it a situation where one battery work like a horse the other simply loaf weakness they both fail prematurely. there are ways to stabilize the situation one is to add a diode in series loss of .7v x amps the other is a small value resistor. either way it is a power loss if enough current is in demand it becomes a very big power loss So it is your call.
  5. creakndale
    Mar 13, 2009
    68
    7
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Italo, please read up on batteries before posting. You have your facts confused.
