I have built the attached circuit and its being working fine but has some hick ups.
The solar panel is connected to J1 and J2, U1 the LM317 is set to 18 Volts. Q1 is so the current to U2 PB137 is limited to 2 Amps.
MINRLY is to isolate the Battery when the Solar panel is not charging.
The Low voltage cut out made of TL431 and IRF9540N is to make sure the battery does not go below 10.6 Volts.
The terminals J4 and J5 are connected to a relay which the load is switched through.
I am experiencing 2 problems that I cant understand.
The first is the low voltage cut out does not always work when I bench test it there is never a problem, However the battery went flat and when I tested it the voltage was as low as 5 volts.
When the panel starts to Charge the TIP41 gets very hot, in fact so hot the heat sink discolours, the PCB also burns. Again I am not sure why
