Solar powered LED strip
Discussion in 'The Projects Forum' started by xMac, Oct 26, 2014.
  1. xMac
    Oct 24, 2014
    8
    image.jpg image.jpg Hi,
    I bought a solar panel a year ago and didn't use until today. I bought an LED light that has around 62 LEDs that consumes 15watts with a 220v converter how can I hook the LEDS to the solar panels do I need resistors? What size? How many?
    I opened tbe LED inclosure and took the attached pictures. I found 62 LEDs that are connected in parallel -am not sure- the whole thing is 15 watts and 1000lm. This is everything I found so far. I wish it is enough to start. Also, the PV is 85 watts and 24 volts. I usually get voltage in the range of 19.
    I'll NOT use the supplied LED controller instead, I'll hook the LED strip to PV directly. The problem is how to do so? What resistors do I need? How to connect them?
  2. xMac
    Oct 24, 2014
    8
    The pictures
  3. xMac
    Oct 24, 2014
    8
    Sorry for the duplicated picture.
  4. ronv
    Nov 12, 2008
    3,404
    1,478
    May be a problem. The controller says 300 ma. and 15 watts. OK so it is good for the led's that say they are 12 watts. So using P=IE it would say about 40 volts to the leds.
    The leds appear to be in series, but 40 volts would not be enough for 62 of them. So something doesn't add up. Can you measure the voltage to the leds?
  5. xMac
    Oct 24, 2014
    8
    Ronv,
    Thank you for the prompt reply. I measured the out voltage of the controller and it showed strange reading. It increases from 5.xx to 30.xx in 5 seconds after that it decreases from 30.xx till 5.xx in another 5 seconds and so on.
  6. ronv
    Nov 12, 2008
    3,404
    1,478
    Was it connected to the leds?
  7. xMac
    Oct 24, 2014
    8
    No ronv it wasn't connected.
    How should I measure the voltage? Is it between the positive and negative of the LED strip? Or in the wire before the LED strip?
  8. xMac
    Oct 24, 2014
    8
    The voltage is 37.3
  9. ronv
    Nov 12, 2008
    3,404
    1,478
    Do you still have the specs on the solar panel? If it has enough power you could use a constant current boost regulator to raise the voltage.
    You can find them pretty cheap on ebay.
  10. xMac
    Oct 24, 2014
    8
    I don't have the specs but it is 85 watts and 24v.
    Can I use dc-dc buck converter?
  11. ronv
    Nov 12, 2008
    3,404
    1,478
  12. xMac
    Oct 24, 2014
    8
    Great ... I'll wire the LED directly to the PV using this booster regulator isn't it?
    BTW, thank you thank you thank you ronv.
  13. ronv
    Nov 12, 2008
    3,404
    1,478
    Not quite so fast.
    The output of the solar panel goes to the input of the boost circuit..
    Then you need to adjust it.
    What would be good for this is a resistor of say 1000 ohms and 2 watts or more.
    Then adjust the voltage to 38 volts while the panel is in the sun.
    Then attach a small lamp - like a seven watt Christmas tree light and adjust the current adjustment to 290 ma.
    Now you can hook the output up to the leds.
    Bernard likes this.
