I'm wondering if it is possible to use ordinary light switches to act as on/off switches for solar panels. They would be placed before the charge controller so that the incoming current could be switched off when hardware on the other side required work. Please note that where I'm located there are NO regulations so I can do whatever physically works for me.
The panels will be wired 2-in-series and the following are the specs per panel:
Max power: 124 W
Voltage at Pmax: 30.0 V
Current at Pmax: 4.13 A
Short-circuit Current: 5.1 A
Open-circuit Voltage: 42.0 V
Max series fuse rating: 8 A
Thanks.
Max power: 124 W
Thanks.
