Solar panel voltage regulator.
Discussion in 'The Projects Forum' started by Carlost, Feb 13, 2008.
  1. Carlost
    Jul 9, 2007
    8
    So I need to build a voltage regulator that will charge a extra battery that I have with some solar panels it asks for at least 24v and 2.5 amps. I had made a voltage regulator that is regulating the voltage at 24v when I plug it in to a power supply but when u put it on the solar panels out side it only gives me 7 to 9 volts and only 300mA or so and that’s not nearly enough to charge the batter any suggestions?? Or has any one built a circuit that could support the 24V and 2.5 amps that I need, the solar panels give me 27-29 votls but i dont think its giving me the current i need once under load, :confused:Pleas help. Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Well, it sounds like your solar cell array is not able to supply sufficient current.
    What is the measured current your solar cell supplies at 24V?
    Take that result, and plug it into this formula:
    2.5Amps/CurrentMeasuredAt24V = NumberOfSolarPanelsNeeded
    You might also try using items like Fresnel lenses and mirrors to concentrate the sunlight on the cells, but beware of overheating them. To keep them cool, you could use a large heat sink.
  3. Carlost
    Jul 9, 2007
    8
    ok thanks so much il try that.
  4. Carlost
    Jul 9, 2007
    8
    Also would putting the panels in parallel be better the in series?? i have them in series now.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Connecting them in series increases the voltage, not the current.
    Connecting them in parallel increases the current, not the voltage.
    Solar panels have historically been quite expensive to acquire, particularly in larger sizes.
    To get the most out of them, you'll need to keep them aimed perpendicular to the sun's rays, or use a steer-able reflector/focusing element(s)
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Open circuit voltage of a solar panel can be 33% higher than load voltage. Ratings given in the catalogs are for peak output, and are also subject to a "negative tolerance rating."
  7. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    If you are trying to charge a 24 volt battery, your regulator will need to output around 27.6 volts
  8. Carlost
    Jul 9, 2007
    8
    Would putting more capacitors at the input give me more current on the output?? In parallel or series?
  9. Carlost
    Jul 9, 2007
    8
    and thanks for your help :)
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    More caps won't make a difference. The solar cells use incident light to make both the voltage and current.
  11. weide83
    Jan 28, 2008
    8
    CHeck out something call MPPT --- max power point tracker... can help to deliver max power
  12. mohmart
    Mar 31, 2008
    can you please draw for me a block digram for this solar power regulator
