I'm playing around with a pretty cheap solar panel. When I measure its output, its in the range of 15 or so volts. When I connect a load to it, it decreases significantly. For example, an led used without a resistor drops the Voltage output to 1.8V. A 1k resistor down to 1V. Why is there such a drastic drop and can it be avoided?
