What is the suitable solar panel to charge a 12v car battery?
S Thread Starter syaf921 Joined Dec 21, 2012 18 Jan 3, 2013 #1 What is the suitable solar panel to charge a 12v car battery?
ErnieM Joined Apr 24, 2011 8,377 Jan 3, 2013 #3 That depends on what the charge controller requires. If going direct (an unrecommended practice) you still need more then 15V.
wmodavis Joined Oct 23, 2010 739 Jan 3, 2013 #4 You planning on hooking the PV directly to battery or using a controller? What is the ampere-hour rating of the battery in question? What do you hope to achieve?
