I want to add a very simple if possible LED circuit to my solar panel to tell me if it is charging. Basically when the voltage is 14 Volts and above I would like an LED to Light when the panel voltage drops below 14 Volts I would like the LED to Switch off.
I have fitted a 30 Watt solar panel to my gate motor, the motor has 2x 12 Volt 7 Ah batteries in parallel. I just want a visual indicator that the solar panel voltage is above 14 Volts. The maximum voltage of the 30 Watt panel is 17.4 Volts according to the specs on the back of the panel
