Solar panel, Charge controller, Battery
Discussion in 'General Electronics Chat' started by Shah_Key, May 20, 2013.
  1. Shah_Key
    Jan 8, 2013
    23
    Hi all
    I have the following 3 items i would like to connected to each other.
    Solar panel:
    Raloss SR100-48
    http://uk.farnell.com/raloss/sr100-48/solar-panel-100w-21-6v/dp/1462498
    Charge controller:
    Sunsei Charge Controller CC-10000
    http://uk.farnell.com/icp-global-technologies/cc-10000/charge-controller-10a-sunsei/dp/1702992
    Rechargeable battery:
    Camdenboss BEG120120
    http://uk.farnell.com/camdenboss/beg120120/battery-europa-gel-12v-12ah/dp/5085330
    I would like to ask if it would work properly at maximum capacity (i.e. maximum power generated from the solar panel.
    Thank you in advance
  2. LDC3
    Apr 27, 2013
    920
    160
    It would depend on what you want to use the power on. How long is the power to be on and what is the current drain ?
  3. Shah_Key
    Jan 8, 2013
    23
    The solar panel will charge the battery
    so the configuration would be:
    Solar panel ==> charge controller ==> Battery
    I want to know if it is safe to use the equipment together like that when the solar panel is at maximum capacity.
  4. LDC3
    Apr 27, 2013
    920
    160
    I don't see why not. The charge controller expects a varying input (in voltage and current, depending on where the power comes from, solar, wind, etc) and monitors (hopefully) the battery charge so the battery does not get over charged.
  5. Shah_Key
    Jan 8, 2013
    23
    Hmm, the thing is the battery has a maximum charge current of 2.4A so i am not sure. does this have much of an effect?
  6. LDC3
    Apr 27, 2013
    920
    160
    I didn't realize that the output of the solar panel was over 5 amps. Did you send a message to the company asking about having a charging current greater than the battery specification?
  7. Shah_Key
    Jan 8, 2013
    23
    These items were purchased separately.
    But the specification of the charge controller states that it should work fine with the 12V battery
  8. LDC3
    Apr 27, 2013
    920
    160
    The information will say it works with a 12 V battery, but in your case, the solar panel can supply more current than the battery can accept. A car battery can accept over 10 amps of charging current. Your battery is smaller, and if that much current is forced through the battery, it will overheat, discharge hydrogen and an explosion may be possible. The safest thing is to buy a larger battery that can handle up to 6 amps of charging current. Granted, it might be more than you want, but it will last longer on sunless days.
    Shah_Key likes this.
  9. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Agreed, the battery is the weak link in the chain. The charging components will actually charge this battery at too high a rate.
    The good news is using a bigger battery (assuming the same load) will lead to a longer lifetime for the battery.
  10. piratepaul
    Member
    May 20, 2013
    35
    I live in a solar power houseboat, have done for over30 yrs... bigger bat.
  11. Bernard
    Aug 7, 2008
    4,233
    414
    Wild thoughts:
    SC I= 5A, best power @ 17 V, so internal resistance about 3.4 Ω; so add about 3.5 Ω on panel output to limit I to about 2.4 A?? ' cannot use bigger battery because it fits my mower.
  12. LDC3
    Apr 27, 2013
    920
    160
    If you need to limit the current, then make a circuit to limit the current to place between the solar panel and the controller.
  13. piratepaul
    Member
    May 20, 2013
    35
    Or a smaller panel... or keep the panel in the shade.
