I am currently working on a project that uses a 6v 4.5Ah battery and 12v solar panel. The battery is connected to a buck converter set to 5v and this powers an arduino and lcd screen directly. When running, the system draws about 60mA-100mA. The specs for the solar panel are
1260mW, charge rate: 70mA. These specs are from the manufacturer so I doubt they are real-world.
The solar panel was bought before the project was put together. Evidently that was a mistake since the panel is under powered. I have looked all over and I can't seem to find a calculation for determining the specs for the solar panel that I need.
Can someone provide a formula on how to calculate this?
