Hello
when connect solar panel in parallel they should be a bypass diode put in the circuit.
So the question is when connect solar panel in series if put bypass diode in the circuit would the solar panel work just as good with bypass diode in circuit or been that this is a series circuit put diode in the circuit would make solar panel produces less volts.
Mrel
Mrel
