I'm doing some research on solar-energy battery charging. I have read the following article: http://www.windsun.com/ChargeControls/MPPT.htm (An article about Max Power Point Trackers) that regulates the current input so that the battery always is charged with the highest power, hence the highest current.
What is not mentioned though, is how the battery can handle this current..? Can any 12 V battery handle these charging speeds applied by the solar panel/MPPT's? What happens after the max current is adjusted by the MPPT, is it just applied to the battery?
